La Camioneta
Looking at our needs, scalability, and utilization outside the bus I'm really wondering why not use portable power(s) instead of a permanently mounted house bank system? Are the portable units that much more expensive than a house bank, once you add labor, mounting, wiring, etc. costs?
We will be using the bus to tour, not live in for any period of time. Being able to utilize those assets elsewhere is a big plus. Saves a huge amount of time guessing where we want outlets and running permanent wiring everywhere.
A big unit like a Delta Max or Yeti to run fridge and water pump for a couple days and then 2-3 smaller units to run hair dryer and other small needs? Generator will run for A/C anyway, can charge pp units at the same time. If they crap out before warrantee, send back for replacement.
