ForestGarden
- Joined
- Jun 25, 2019
- Posts
- 17
Converted an early 2000s Ford E450 Powerstroke Diesel 7.3 - 117k miles, seems it was well maintained until it sat for a year or so. I have it parked off-road and jacked up in the woods on the property where I live. My intention is not to drive it, as I have no plan to move, but perhaps one day I will move or want to sell it. That could be one year from now or 10 or never. I'd like to maintain the mechanics of the bus to be able to do that. I am not wanting to put a bunch of money into it to stay in peak condition, just need it to run. I know a bus is a bit silly for not planning to move, but I got the bus dirt cheap! My whole project is cheaper than a tiny house trailer would have cost alone...
Its not possible for me to move the bus to drive it and get it hot on occasion because of how it's jacked up and off road - it took 4 days to get it jacked up, don't ask! I have read multiple threads and seen mixed things, but nobody who is in my exact situation and I am looking for advice.
One more note - when I was moving it around, the "water in fuel" light came on -- probably condensation in the fuel tank? A mechanic working on something else said the fuel was nasty when he looked at it.
My current plan is to drain the fuel, drain the water separator (any insight into how to do that? Seen videos of similar process but none for this bus model...), replace fuel filters, top off all fluids including fuel, add fuel stabilizer and biocide, and then let it sit.
One consideration -- since there was water in the fuel, should I run the bus one more time and, while in neutral, push the pedal and rev the engine for 30 min to cycle fuel thru the system and "burn off" any potential nasties in there? Will it get hot enough just revving the engine in neutral? Should I do that sort of thing once a month, or just leave it sitting?
Another consideration -- filling a ~50 gal fuel tank just for it to sit unused and go rotten after a year sounds expensive and wasteful. Could I just put a few gallons in there and drain it every month, give away the fuel to somebody, and fill it back up with fresh fuel? I know that would allow condensation but if it's drained monthly would that be enough water build up to cause rust or engine issues if fuel isn't moving thru the system? I'm willing to pay for the fuel to fill the tank if that's whats best.
Anything else I'm not thinking of?
Thanks!!!
Thanks!!!
