musigenesis
My bus maintains 120 PSI while driving with no apparent problem, although if I let the bus sit for a couple of days the pressure drops to 30 (haven't found any leak externally yet although I haven't spent much time trying) so I obviously have a leak somewhere.
When I'm driving, sometimes the low-pressure beeping comes on for a good while even though the gauge is showing 120. At least I think it's the low-pressure gauge since it's making the same noise (everything on the dash is in normal range).
I'm planning on taking my bus to the mechanic ASAP to have the leak looked into so I'll have them look at the beeping problem too, but I was wondering if anybody here had any insights into what might be causing it. Maybe the beeper is the leak?
