lee.wissmiller
- Joined
- Feb 2, 2019
- Posts
- 15
So I have been reading up on insulation and I have a question:
If foam board Insulation has an R value in the 3-6 range per inch and blown foam has a slightly higher R value, has anyone found something with a higher R Value?
I found this insulation (which if I can believe all they say about it sounds ideal) which a much higher R value (15-17) for a much thinner material (5mm) and is specifically designed to be applied to metal walls and roofs (still unsure about using it as flooring). I would think the higher R value would make for a better insulation. While the cost is a bit high, it is not insane (especially to make the R value of my walls and floors 2-3 times higher) and would curve around the roof without having to cut and losing some R value there. It would also be a much easier application than traditional board or blown insulation.
Prodex ( https://www.insulation4less.com/default.aspx )
Does anyone have experience working with it? It looks like reflectix with foam insulation instead of air bubbles between the layers.
