Propane DOS and DONTS
Propane stops working around -42 degrees (F and C!) because it is too cold to be in gas form. Do not recommend!
Cool, maybe a bad word choice! I did not know that so ty! Temp back to more reasonable -6 right now and to +4 this week so I should be ok.
Actually the pilot runs all the time so maybe that heats the controls enough to operate in the cold with a stove or fridge.
Strange stuff you guys have freezing up at so warm a temp though.
Stay warm,
Most problems with breakage aren't caused directly by propane, but by water that has contaminated the system (broken regulators) and by components that operate on water (on-demand water heaters)
From what I have found on line, if you are planning on mounting your tank in a compartment under your bus, you’ll want an ASME approved tank vs a DOT approved tank. The latter are for external mounting.
