ATRaven
What kind of piping should be used to pipe propane gas?
Thank ya'll
Thank ya'll
Please be safe ! Just a reminder for those who haven't read this post:
http://www.skoolie.net/forums/f11/the-camel-conversion-project-7052-43.html#post94041
Copper is notorious for "work hardening" and cracking after much exposure to vibration.
Yet in practise it has been used, and is still used, in both American and European RVs with no ill effects, and has been for decades.
That is an odd story.
You need a pretty rich mixture to ignite propane and with the odorant they put in, you should smell it way before the mixture gets rich enough.
As for piping, go black iron but try to use the minimum of fittings. I would rather mandrel bend black iron pipe than use an elbow with Teflon tape.
When you do have to have a fitting, I like the natural gas rated yellow Teflon tape that is nice and thick. I've tried pipe dope with poor success but relatively few issues with good Teflon. I like to think of Teflon tape as an art, wrap it tight, cut the ends square and massage it in to the threads a bit. Doing that consistently makes me avoid second guessing my work and I can usually tell when I'm looking at my work.
I'll be slightly upset if I need to use more than 10' of black iron pipe or more than one bend, you should design around your propane system, not design your propane system around other stuff (except the chassis).
If you have any electronics that might be an ignition source near your propane tank, make sure it's in a cabinet vented outside and sealed from the space where propane could fill.
Close your tank valve before you move the bus.
One more thing, there are electric propane sniffers available now, maybe there is a type that could be mounted in the basement like a smoke detector?
What size ( ID) black pipe for plumbing propane?
I just did a job with 6 heaters at 60,000 BTU each 360,000 total on 400 ft of pipe and it was 3/4 sch40 the entire way
