DT Rutledge
- Joined
- Apr 14, 2015
- Posts
- 53
I've read all of the pros and cons in the cummins forums. Any thoughts on propane injection in a 5.9 12 Valve/ allison MT643 in a RE Thomas? I will certainly have enough propane on board.
I have had interest in this as well. As you did, I have spent hours reading & studying the subject.
I am quite convinced that, properly done, propane injection can improve power, economy and reduce EGT's.
I have looked at it from an economy standpoint. Today I can buy diesel for $2.39-$2.59 in my area. Propane is generally $2.99-$3.29 a gallon.
What I have been completely unable to quantify is: How much diesel would I save after consuming one gallon of propane via injection?
I had considered the idea of an accurate fuel flow meter (2way) and a high refresh GPS to facilitate testing.
I would place fixed orifices in the intake and use a variable pressure regulator to vary the propane flow.
I could set up a particular driving situation and vary the propane flow while documenting driving condition, propane flow, fuel flow and speed.
I have some other ideas such as using an RV "safety valve" on the propane tank. It is a 12v solenoid valve that controls the propane flow at the tank. No power = no propane. I would control this valve with an oil pressure sensor. No oil pressure = no propane.
Several of the installs that I have seen are a simple "on/off" fixed flow setups. I really think that some kind of staged or variable approach would be more effective.
Without testing, I am clueless as to what to base the variable flow on. Throttle position? Boost? EGT? Some combination?
Any Arduino wizards out there to build us a controller???
Just some random thoughts from a guy with an overactive imagination...
Have Fun!!
S.
