whole page of nothing.
Issue is regulated pressure. Chances are the regulator vent is plugged at minimum. regulator bad at max.
It's not your damn hoses or stove.
If your regulator vent is plugged flames will lift off the burner to start then back burn into the burner as pressure decreases.
This is why i stay off the forums more often than not. Takes 36 pages to get a straight answer and then your so over loaded it seems like gibberish.
Must be old school. I don't answer unless I have a clue.
It amazes me when someone can drop into a thread and diagnosis, trouble shoot and.. find the ultimate solution right of the bat. With out even fixing the problem.. !
It is either a profound shinning intellect made up of insight, prophecy and possibly magic that lowly humans can't fathom. Or a complete idiot who makes a guess in the troubleshooting process and wraps it in divine ego.
Maybe you can change your avatar to a green check mark so we always know that the solution has been found and not waste time on the rest.
Meanwhile the poor guy needing help has been chasing hoses, fittings and replacing equipment
Sorry, the issue is obvious to anyone who does the work for a living.
I'm licensed up to building railcar transfer stations and marine systems.
