jholbert
I have been looking for a good propane tank to use for my Skoolie conversion. I have decided on a 100 lb horizontal propane tank (~23.6 gallon). I have found a few options that range from $240 - $750. Can anyone provide insight into good propane tank brands that have this capacity tank? Below are two of the tanks that I am considering. Has anyone ever used the Flame King propane tank for $240 and can provide their opinion on it? I am not opposed to spending more than that on a tank but if it works well I don't see any reason to spend more. The other tank below is slightly smaller but more than twice the cost. This makes me very hesitant to go with the cheaper option. Most other tanks I have found around the $500 range seem to be out of stock everywhere.
Thanks in advance!
Flame King $240 - https://www.walmart.com/ip/100-LB-Pound-Horizontal-Vertical-LP-Cylinder-Type-1-OPD-Valve/183242553
Manchester 19.2 gal $540 - https://www.camperid.com/manchester-tank/manchester-tank-14-x-40-asme-tank-2038816195.html
Thanks in advance!
