$400 bucks on a scanner that YOU WILL use again in the future.... Me I have a scanner and when the bus rolls, so does the scanner... I consider this a MUST HAVE if your gonna drive a bus!
What you need today is a tranny scanner and not an engine scanner.
If you have an Allison 3000 you can pull tranny codes thru the pushpad. If you have an Allison 2000 your gonna need Allison doc.
If you have a 2000 tranny you can also do the "Limp home" test to find out if it is electrical or hydraulic, the tranny failure.
Limp home test, post #17
I have a 2007 Thomas c-2 Freightliner I bought with Check Transmission light on.The bus did move with no problem when I got it,then it sat for a while and I had to floor it to get it to move,reverse was fine.Now it won't move either way.I read all the stuff about brakes being locked...
www.skoolie.net
Link-> Allison 3000 manual, post #11
Hi! New Skoolie owner here! My father-in-law bought us a Skoolie and when driving it to us, it began having trouble with transmission (Allison transmission?). They aren’t able to find anyone to work on it to get it to us! The certified Allison transmission mechanics won’t touch it because it’s...
www.skoolie.net
pulling trouble codes
download this md3060 operators manual and on page 23 of the PDf you will see the process on how to pull trouble codes thru the pushpad.
have a pen and paper ready because you have to count how many times the light blinks.
