lawdog71
As I continue to research my wants and needs, wonder what the pros & cons of rear engine or forward? Your thoughts?
~Scott
~Scott
I googled it, but could not found how a rear engine bus is setup, does it have a normal front engine transmission and a short driveshaft? Cars use transaxles which integrate the differential with the transmission to keep the length short. Probably not a priority for a bus. The issue with transaxles is making them matchup with different engines is not simple, but it is simple in a front engine, just a new driveshaft is needed if you swap engines.
Flat nose buses have more interior space.
Nope, rear engine buses just have the rear end facing towards the back of the bus. The engine and transmission mount behind the rear axle and then there's a short driveshaft that feeds into the rear end. Nothing at all like a rear engine car.
The main advantage of this is the ability to build massive understorage compartments between the axles and completely enclose it without having to work around an exhaust pipe or driveshaft.
Thanks. So just a different the rear axle and engine swap would be no problem. That makes the 1953 non-running bus for sale more attractive if I can swap a V10 into it.![]()
Yeah no rear bedroom for us :whistling:You lose rear access to interior on a rear engine bus. I have a "garage" in the back of mine that would not be possible on an RE. Easier rear bedroom in an RE than an FE.
I would have wanted a pusher...but I was worried about having the long front and rear overhang. Dog nose also means I could have a manual transmission and I really love the manual.
I've heard of a coach or 2 that were pushers with manuals but that linkage has to be 30 foot long!
What a RE loses in rear access for the garage it gains in under bay storage. I don't know what to do with all the potential pass through storage space i could build, all with no sacrifice to interior living space.You lose rear access to interior on a rear engine bus. I have a "garage" in the back of mine that would not be possible on an RE. Easier rear bedroom in an RE than an FE.
Rear engines are quieter but make it harder if you want a rear deck or are going to tow something.
