surfskool
I tore up my skoolie's floor and, as most people here, found that the plywood was rotted out.
My approach to sealing up the floor has been a bit scattered because I'm taking advice from too many sources.
First, I used an angle grinder to get rid of *most* of the rust, but some of the thin sheet metal seemed to be more rust than metal.
Then I took the advice of a friend and used a spray paint that was supposed to convert the rust back into metal.
Then I used a thin coat of rust resistant paint. My three little neighbors (4, 8 and 9) helped me paint so it was a bit chaotic and had lots of little shoe prints/slide marks
Then on the advice of a friend I ground around the holes (where the seats were attached) and we welded up the holes (some with metal plates, some just with welding).
So now what I've got is a floor with some rust conversion spray, some rust resistant metal paint, some bare spots that were ground out and welded.
So the question is, what would you use on top of this mess to properly seal the whole thing?
I got two 6 mil vapor barriers on the advice of a Home Depot employee, but then another (perhaps more knowledgeable?) friend suggested using POR 15 instead- he said that having a plastic vapor barrier against metal was like putting plastic gloves on your hands- soon the moisture would make the whole thing wet and rust it out. So he said POR 15 then plywood, then the padding and carpet I've got.
I know there are lots of threads on sealing the floor, but I'm wondering if anyone has expertise to advise me given the fact that I've already thrown a hodgepodge of crap on this floor (see the part in bold above). I am happy to report that I think all the major holes in the floor are sealed, now it's just time to deal with leaking windows and such.
Thanks in advance for any help, I'm so excited to have found this site!
