lblampman
Hi All,
Ok, my new-to-me Thomas has a set of split air-operated entry doors. To the left of the driver's seat is a toggle switch with which to open and close the doors.
On my bus the doors appear to operate as they should but they will not stayed closed at speed; they pull open about 6" or so varying with wind conditions but anything over about 35 mph usually has them opening a bit.
I took the panel above the door apart and found a large air cylinder attached to the doors with various bits of linkage. All the air lines seem to be in good shape and when the toggle switch is repositioned the air cylinder appears to operate correctly. But...when the doors are closed I can push them open albeit against some amount of pressure but it doesn't take a huge effort. I also can't hear any air leaks above the door, in the cap compartment above the driver where the air line runs across, or near the toggle switch (which I suspect is electric and not air just due to "feel").
I don't understand what is really supposed to happen never having been around air-operated doors before. Once the doors are closed should there be enough air pressure in the cylinder to make it all but impossible to push the doors open? Is it air pressure alone that keeps the doors closed? I don't see any "latching" arrangement for a mechanical system.
I'm a little familar with air cylinders that receive air pressure to activate something then the air is released to return to a rest state. It appears the air actuator above the door in my bus may act like a hydraulic actuator and get "pushed" from each direction as necessary. Anybody familiar with the mechanism that does the switching for that? Or if it even happens with air actuators?
I plan to replace the split doors with a 1-piece swinging entry door but since that may not happen really soon I'd like to get the current door system working well enough that I can drive the bus without the doors opening on their own. It's a little disconcerting but it's also COLD!
Thanks!
Thanks!
