I installed all the ½” PEX tubing in the floor when we built out the bus, and I recently finished setting up the radiant floor heating system. It’s incredible! In cold weather (below 10°F), it keeps the floor between 70–90°F and helps the mini-split stay effective.
Here’s how the system works:
1. Reservoir Tank: The loop starts in a small ½-gallon reservoir tank mounted under the bus. This tank collects return fluid through the cap, which drains out via a ⅝” outlet at the bottom.
2. Pump: The fluid is moved by a 4 GPM AC-powered pump. While it’s effective, it’s fairly loud inside the bus (about 69 d
. Both the inlet and outlet are ½”.
3. Heater: The next step is an AC car engine heater. Both the pump and heater are plugged into an outlet under the bus, which is controlled by a switch inside, so I can easily turn them on and off. Like the pump, the heater’s inlet/outlet is ½”.
4. Manifold: From the heater, the glycol runs through a manifold with shut-off valves, allowing me to heat the bus by zones (front/mid/back). Fluid temperatures entering the manifold reach around 140°F.
5. Loops: The heated fluid then travels through the loops that warm each zone. Floor temperatures vary between 70°F (between loops) and 90–100°F directly over the loops.
I started running the system a couple of months ago, just before Thanksgiving. At first, it worked great! While the pump was noisy (around 70 dB inside the bus), the heat was worth it.
However, I noticed the pump sound changed, and when I checked, the glycol was low. I added about ½ gallon of glycol, and the pump sounded better. Soon after, I discovered the heater was leaking from a seam. Since then, I’ve had to top off the glycol every 10 days or so.
When temps reached the high 20s, I turned the system off during the day. But during a 10-day cold snap with highs in the teens, I ran it constantly. That’s when the pump sound changed again. This time, the fluid levels were fine, but the pump wasn’t functioning properly. After shutting it off to cool, I tried again, but the pump still seemed dead. Unfortunately, it’s been too cold to remove and inspect it.
Here are my questions:
1. Could the heater be leaking because the system pressure is too high? Is there an affordable alternative to a hydronic heater?
2. If I switch to a 3 GPM DC pump, would it reduce the pressure while still handling all three loops? A 2.1 GPM pump looks more suited for a fish tank—would it even work?
Thanks in advance for any advice!
