Simplicity-SKO
I searched before writing this, but couldn't find an answer.
My engine runs fine. Builds up it's coolant temp to between about 200 and 212, the oil and tranny reflect this same range within a few degrees.
After the engine cools, my top radiator hose collapse. I understand that means there's a vacuum in the system.
My research tells me that it's either a bad coolant cap, a clogged line between my expansion tank and radiator, or somewhere else in the cooling system and finally, bad hoses.
What I've done:
I replaced my cap and unlike the old one, the mechanism seems to be functioning, yet there's still a vacuum. It's a 10psi, Dorman (I believe), cap. I screw it on until it clicks.
If I unscrew the cap, the hose immediately expands.
I'm assuming that since the cooling system is keeping everything cool, that it's unlikely that there is a clog somewhere.
Per the hoses, while they will be replaced soon (adding a tranny cooler, running new heater lines and changing coolant and filter), they are functioning with no signs of leaks. So, I'm assuming they are okay.
Since when I unscrew the cap the vacuum releases, I'm assuming that if the cap were working properly, the vacuum should release through the cap (no need to unscrew it).
I'm sure you can get a bad "new" cap, but before I go buying another cap, I wanted to see what all you wonderful people think.
What I've done:
