Robski-SKO
Looking for some help with the radiator swap on my 2001 AmTran International flat nose. I was running a bit on the warmer side since I started flat towing my F150. I thought it would be a good idea to pull down the front grills and bumper and just do a good wash down of the radiator and inner cooler fins. Upon further inspection, I should've never removed the grill as everything is rusted out, Michigan bus. Ignorance is bliss right. hehe.
Now, here I am. I have the radiator, inner cooler, and radiator bracket out. After getting into it, I think I did the wrong process for pulling the Rad. I pulled rad out of the bracket first. It appears maybe the rad bracket swings out on the top... In the process everything was rusted. Most bolts snapped. Not a huge problem most nuts and bolts can be replaced. I need to find replacements for the isolator bolts at the bottom of the rad bracket.
Real question:
Is there any parts breakdown resources out there for finding out what items are on the bus, where to buy them, or the like. I feel like an a-hole calling dealers and online resources with, I need this part but I don't know what it called. LOL
Real question:
