Hello, I have a 1998 Freightliner FS-65 with a 5.9 Cummins and the electronic throttle. Randomly the engine will redline for no reason. The throttle is not being pressed and when you press it, the engine is under control, until you let off. The only way I found to stop is is to restart the bus. I have only had it happen once to this extreme, it will randomly surge a bit. Only after 25-30 minutes of idle (I was charging the batteries after jump starting) Does anyone know why this happens? I'd like to know.
