elkoskoolie said:An electric trailer brake controller simply taps into the brake light switch at the pedal. A heavy wire is then run from the controller to the trailer wire receptacle that the trailer plugs into. You may need to change the plug, i.e a flat 4 wire trailer plug does not have a brake wire. I don't think it should matter what kind of brakes the tow vehicle has.
