LittleBusBigDreams
- Joined
- Apr 6, 2023
- Posts
- 13
Here comes another "T444E / AT545 need lower RPM's on the highway" post
1997 Thomas Vista 3600
I had the local International parts guy pull the rear end info using my VIN and was told it's a Dana model 15500 (can't find this model mentioned anywhere?) with a 3.39 ratio. My tires are 245 / 70 R 19.5 and measure 32.25" in diameter.
When using an online calculator with 3.39 gear ratio it calculates very close to my actuals:
50 mph @ 1866 RPM (80 kph)
55 mph @ 2052 RPM (89 kph)
60 mph @ 2239 RPM (96 kph)
When I spoke to a local drivetrain shop last summer they mentioned a 3.2 ratio would be the next step, which only drop ~100 RPM at highway speed:
50 mph @ 1761 RPM (80 kph)
55 mph @ 1937 RPM (89 kph)
60 mph @ 2113 RPM (96 kph)
I would love to cruise at 60 mph around 2000 RPM, which would land me somewhere around 3.0.
This leads me to some questions:
1) Is 2000 RPM a reasonable cruising RPM? From what I know it's in the peak power band, and should be more reasonable on fuel vs my current 2300 RPM cruising speed.
2) 3.0 seems very low for a skoolie. From what I've read most busses seem to be in the high 3's or low 4's. Is 3.0 recommended or even achievable?
3) I already slow down significantly on the hills, and I believe i'm usually in 3rd gear doing 30 mph at the end of a long hill. At 3.0 I realize I'll have less pull up the hills, but am I naive to think I'd just end up in 2nd gear doing 30 mph?
4) If I end up tinkering with the rear end, I imagine I should try to end up with a posi / limited slip setup. Plan to spend a lot of time on logging roads and some extra traction seems like a good idea. If you have experience/advice in this regard it would be appreciated.
Thanks in advance for any input!
