I've removed my rear heater in my '94 E350 Short bus. I turned off the 2 hose valves under the hood when I cut the lines, and only lost about a quart of coolant from the lines. The question is what to do now? Can I simply leave those valves closed? Or will that disable the front heat too? Or should I just make a loop behind the valve panel under the hood?
