nikitis
Goes without saying, but don't forget to back up your current config in case there's a problem, you can replace the hardware and flash original to it.
Looks good christopher. I think full cure on the rtv is 24 hours. I usually let it sit overnight as well. I've rushed some back into service right away and had no issues. IDK if there is any difference with the permatex gear oil rtv or standard rtv, but I've had no issues with the gear oil specific stuff, so I keep using what works.
S-series internationals had an adapter box in the speedometer cable for different ratios. I think they only had a gear or two option, but loads of different adapters. I had the chart for all of them at one time, but deleted the file when I sold my bus. This is what one looks like. https://www.ebay.com/itm/223068999245
Modern way with servicemax is so much easier LOL
Looking forward to an update on how your drivability has changed, I think this upgrade was likely a long time coming.
How did the bus do moving from dead stop? Did it move with a bit more urgency??
That's great news and thanks for the follow up. Perhaps the U-joints may need to be replaced?
I don't think you deviated much from what you had originally to cause vibrations. Could it be possible the tires just need to be run for a bit since they sat? If you feel it's driveshaft related, have it balanced. We have a driveshaft shop near us that does this. They can build you one from scratch if need be. You may have a similar shop. Balancing would be beneficial even if it is not the root cause. Eliminates that part at least.
I only say that since the cost isn't a huge amount and it scratches the driveshaft/joints off the list and may improve the smoothness regardless once the real culprit is found. The only other thing I can think of is the differential gear set back lash? Not sure if I am saying it right.
A single u- joint does not follow the same angle per 360bdegree rotation.
To compensate for that both u joint need to be inline. But that does not change the fact that the drive shaft itself changes angular velocity per revolution. On top of that the angle between the first u joint and drive shaft and second u joint and differential need to be the same as well. The result is that the drive shaft does not rotate at constant speed but increases speed and reduces speed with one revolution.
So basically your transmission output shaft should be inline with you differential input while under normal driving conditions.
Maybe your driveshaft has a spline in the middle or at the transmission side that rattles a bit when the u joint angles are not zero. It would be worse if one is different then the other.
Regarding a zero angle and non moving needles, yes in theory but every bump lets them move a bit and the needles are in general without cage, that is against each other so they will wear from moving causing similar issues. I have seen damaged cups but only when they were not maintained ,that is grease .
Happy it all worked out.
Johan
