Reinvent the wheel... forklift batteries and solar.
Dielectric strength of air seems high at 3 megavolts per meter (76 kV per inch) (as per wikipedia) however that's the voltage needed to spontaneously arc across a gap. The wikipedia article also notes that "Because dielectric materials usually contain minute defects, the practical dielectric strength will be a fraction of the intrinsic dielectric strength of an ideal, defect-free, material."
The subtle point made by jazty is important: when a current is mechanically switched, there's an arc. There's always an arc; we just forget it's there because it is contained inside the case of the switch and we don't see it. If the switch isn't up to the task for the current and voltage being managed, the arc may endure longer than it's supposed to (even indefinitely). That's the principle behind dc arc welding -- strike the electrodes together, whether buzz box, MIG, TIG, whatever -- then pull back and maintain the arc. So long as the source can keep enough current flowing to keep the air hot and ionized the arc will survive even with just a few tens of volts. Anyway, that's part of why seemingly low voltage dc can still present a fire hazard, and it's why the variety of published dielectric strengths for air don't really matter to low voltage equipment.
As for converting higher open circuit voltage solar panels down for 12 volt batteries versus other voltages: I suspect step-down aka buck converters can be designed to achieve similar efficiency levels regardless of the input-to-output voltage ratio. Historical inertia more than anything else is probably what keeps us coming back to dc designs at 12 volts.
Good info & well put!!
As to the last point regarding higher voltage panels on a 12v system. That is where MPPT charge controllers shine. The last Outback controller I fooled with will support series strings of panels up to 150VDC. The MPPT controller handles dropping the voltage to the appropriate for your system (12,24 or 48). Running higher voltage strings allows for lower voltage drop and/or smaller wire size from the panels to the controller.
Diesel appliances
I am looking for diesel heat (water, furnace, stove). I would like enough solar to run air conditioning. The gf wants a dryer. I just don't see that one happening. Anyone make one of those in diesel?
Diesel appliances are pretty spendy. I'm pretty sure you can get all of those, except for the diesel dryer. I don't think they make one of those.
It's a bit of a stretch to run AC off of house batteries, especially if you've already got refrigerators and other appliances running. A lot of people have dryers and washers for when they're plugged in to the grid though.
If you're into making things, you could modify a gas dryer so that the diesel exhaust from something else flows through the existing heat exchanger instead of burning gas in there..
Just so happens I have an extra gas dryer that is only blocking a door while being used as a table. The interlock went bad and the ex bought a new one. Not that I was going to rush over and fix it. But since I'm back in the house (she's out) and left the dryer behind, I fixed it. I've no idea what the heat exchanger in it looks like. Only fooled with the interlock. I'm going to have to check that out. Thx for the idea.
