LisaRiel
In my 1993 Bluebird, if I remove (cut off) just the "lip" where where the seats were mounted, but leave the 8 inch metal section, will that compromise the structural integrity of my bus? Thanks.
so is the inside skin but we all remove that. she wants to know if its ok to remove it. the answer is yesDepends on the bus. In most, the seat rail is indeed a structural component. There has been quite a bit of discussion on that topic here.
If you want to maintain the structural integrity of a School Bus then put all your inner sheetmetal back on & reinstall all the seats you removed, reinstall all windows that were removed and or lower your roofs back to where they were.
The moment you change anything you have changed the standards a School Bus has to meet but you will still be stronger than a S&S
Depends on who you talk to. The inner skin discussion is another one that has gone on for years with lots of unqualified input. The only definitive opinion on this site came directly from Blue Bird stating that the inner skin was indeed a critical structural component and not to be removed. Go where you want. I'll stick with what the factory engineers have to offer.
All of the items that you spoke of removing have screws or small bolts holding them in. And you are after all replacing what you remove with new items.
Cabinets, walls, and when you reskin the Windows it makes that part stronger.
The chair rail is welded or riveted every few inches so to make it harder to removed to help keep the structural integrity intact. JMHO
Plus I might add, that I know nothing about nothing
