Hi all, been doing some window research and I'd like to gather some opinions.
I've narrowed my two options down to this:
1. Paint the inside of my existing windows black, spray foam over the windows and frame from the inside.
2. Pull the window and skin with 18 or 20g galvanized steel, glued to plywood. Spray foam and frame.
Option 2, as I understand it, is the preferred way to go as far as insulation goes. But, I just don't know if I like the look of it, and the added cost is a detractor. Will replacing my windows with steel really be that much more effective, insulation wise? Is there any way to replace a window-pane from the outside should one break and I have it framed over?
Thanks, - L
Thanks, - L
