Here is a link to a rivet removal tool for different size rivets. https://www.aircraft-tool.com/shop/detail.aspx?id=1341A
It is used a lot in the aircraft industry. Hope it helps.
Sojourner, is that a 100 gallon tank you dropped from yours? Looks like a bigger job than I was picturing in my mind.
Standard 65 gallon fuel tank, in case that's what you're referencing.
I don't have tractor cheater, so I'll have to see what a nightmare my 100ga. will be to drop and clean.
I managed to do a little body damage and break a couple of windows as well![]()
If you set it up correctly with a couple floor jacks and an extra set of hands you should be able to do it fairly easily. Patience with an eye for safety is the key here. Its mostly just me working on this thing so my tractor is just another set of "hands". I ran my own mobile marine business for a good number of years so I'm pretty adept at moving heavy things around alone.
Took me a minute......
I started reading that and wondering "how in the heck is a floor jack going to help?"
Just catching up on this one?
And I might have missed a part?
If your interior walls are off and the ribs exposed? Why not cut the interior side of the buck rivet flush to the rib and punch it out instead of trying to cut the head off.
I'm not quite to this stage in my construction, but had thought about doing exactly that when I saw what it looked like with the inner walls and ceiling exposed. Will report how it goes using that method. I had thought about either using the air hammer/chisel to knock the back side off, or grinding it flush and then popping it outward.Just catching up on this one?
