So, all of my interior skins are down and I'm ready to measure for new skins. If you've done a roof raise or seen a roof raise, please let me know how to measure.
On my bus, I have 8 feet on center from what would be the A pillar to the window behind the driver's seat. This is where the convenient stops. The rear is 7 feet on center to a rib. Now for the real questions... I'm thinking I want to alternate the skin from one side to the other. Use a single sheet to the 8 feet on port and then use a 10~12 foot sheet and go to the next rib on starboard or something like that. The door is 40" so I could stagger using it. Thereafter all of the ribs are 25 or 32 inch on center. Nothing remotely standard for sheet metal.
Next question is about overlapping. The ribs are a C channel like below... They measure at least 2 inches from edge to edge. I think they measure closer to 3 inches actually with A, B, and C all being roughly 1 inch each. Is that enough overlap? So, for the red sheet I should, "shingle" it as in 1 or alternately "stack" them like 2? I don't remember how the bus is put together OEM. I'll have to remember to look at that this afternoon. As long as C and D are 5 feet apart the "crooked" sheets of 1 won't be too noticeable.
