Morgan-SKO
Hey,
I bought my bus a few months ago and I'm working on getting the walls and ceiling off to insulate and whatnot. The issue is that they are riveted into place.
So I've been punching the centre of the rivet out then drilling the head off. It's tedious but manageable, sort of.
I've managed to bend 3 punches so far. I'm assuming that it's because I'm using the cheap home depot one. Would a better quality punch be worth the money?
I'm also going through drill bits like you wouldn't believe. At first it's like 15 seconds per rivet. It takes longer with each one, after like 20, it's up to over a nimute each. Doesn't sound too bad, except there are thousands of rivets!
I'm buying drill bits for metal but that doesn't seem to help. I've easily spent $100 on bits and barely made a dent. I bought a sharpener but i guess there is a bit of a learning curve because I think I made my practice bit more dull!
Where am I going wrong (besides buying a riveted bus rather than one with screws)? It's becoming frustrating and expensive.
