golfersmurf57
- Joined
- Sep 30, 2017
- Posts
- 386
ECCB that defective tape is stronger than the stuff they use in nascar
Sent from my LGL64VL using Tapatalk
It's looking good. Weird how some places take all the school wording off before you get it but they let you guys drive all that way. I think the lettering does help with the invisibility of buses.
I'm jealous of your engine accessibility.
ECCB, I have the option to purchase this bus. Does anyone know anything about it? Thomas Bus with Cummins 8.3 motor. Looks similar to yours.![]()
The only decal remaining is the large "SCHOOL BUS" above the windshield.
May knock that out in a little while or just do it tomorrow.
An 8.3 in a bus that short would be wild.. and unlikely. Can you get the VIN #?ECCB, I have the option to purchase this bus. Does anyone know anything about it? Thomas Bus with Cummins 8.3 motor. Looks similar to yours.![]()
Sent from my SM-N950U using Tapatalk
Your luck is still holding out, because this coolant problem didn't occur on the trip from TX.
Sorry man I don't know your engine.?
To me the thermostat housing and the water pump housing is and should be seperate from the timing chain itself and its cover?
Unless your water pump,thermostat housing and timing chain are cast as one piece which might have been an idea but never should have been produced?(my opinion)
Not suggesting it but I have seen mechanics back the bolts out enough to seperate the flanges off of whatever without removing anything. Then they would cut/slot the bolt holes to the inside and snip the bottom(cause that's where the leak will show) clean the fragments off and slip the new gaskets in with a lot of high temp silicone/gasket maker?
I don't do that but I would start with the thermostat housing and thermostat and not the timing chain cover.
If your water pump is above/around/over the timing chain cover then I would look at the weep hole in the bottom of the water pump. If it is that then the radiator fan could be blowing the coolant back onto the top of the timing chain cover and running down?
Good luck
