tomas_maly
So I stumbled upon this approach to insulating the ceiling from the outside...
http://www.busnut.com/artgm04.html
I'm already 6'2" or so and so I can't touch the inside of the bus, neither the ceiling nor the floor (I can probably insulate the floor from underneath). This insulation on the roof sounds great, but how do you avoid leaking between where the layers of aluminum overlap? Siding on a house is a no-brainer, as each piece above the other overlaps the top of the piece below, so water can't get in the walls. But what do you do on the roof of a bus?
The aluminum isn't fastened across from driver's to passenger's side - only from front of the vehicle to back. This guy says not to fasten it on top when the temperature causes expansion in different seasons - but then how do you prevent gaps that could easily gause water to leak in? I don't see any mention of adhesive where they overlap. I don't imagine there's adequate slope between the layers (which seem to be almost perfectly horizontal) to guarantee water from not leaking in. Maybe I'm missing something.
