Hello so I’m looking to raise the roof and have been wondering from a engineering standpoint what the most sturdy oem design would be .
Colorado coach works has there hat channels they sell . Kind of plug n play.
I live in Houston and have contacted a few stew suppliers but have had no luck in getting any of them to be able to break 14g I’m the same dimensions hat channel as oem on my international bus....
I was thinking of lapping the hat from the inside or outside but that wouldn’t be as flush for the panels to sit on..... or be riveted too.
So I started thinking even if ordered Colorado’s coachworks hat channel . My bus wasn’t manufactured to have a roof raise . The ribs were probalay specifies and plotted out to be the height they are for a reason relevant to everything else and how the bus was made....
So what if I get the hat channel from them... extended my roof up about 20 in... then add square tubing I side of the hat for extra strength ....
and the square tubing will be not only run the length of the raise but hopefully about 4ft ... then drill holes in the hat and plug weld the square tubing to the inside the bus....
Is this just overkill?
I’m willing to do it as i like to overbuild ... and it’s just another reason to not be paranoid .
Also ...
the bus is International ... i wanna stick with what i see as the outside skins being 16g but i also can’t get a really decent point to slide my gauge on the skins ....
I’ve seen another guy on YouTube (off grid Skoolie )
Use 16 and no oil canning or anything so seems like a good deal.
Transcend existence Wess ha a little bit of oil can effect going on but I’m not sure what gauge he used .
I’ve also been watching his raises he’s done in Washington and San Fran . Over and over again . I plan on doing that style ....
So any opinions about is this overkill?
Also what factory skin International used ?
What if my plates that I welded to my tubes for the all thread jacking method aren’t perfectly square ??
And last but not least I need to understand and order solid rivets .... and my sheets . And vhb tape...
The suppliers around me aren’t familiar with paint grip or paint lock and keep saying they have galvanized ....
I need some sizes of rivets others have used that might work out for me too.
Also ...
