johnsmithx1974
- Joined
- Sep 22, 2019
- Posts
- 5
Is it safe and possible to do a roof raise and not weld it up, but maybe using steel tubs and bolts?
I think nat-ster did a bolt on style roof raise. He got kicked off the sight. do a search to find his old posts.
He got kicked off for using bolts?
Absolutely the King of Douche. But he did a bolt style roof raise if my memory is correct. Anyone remember that?
You are so correct! When I weld, I almost feel the weld. Since I use a torch, it talks to me as well.^^^^ Jack knows! great post.
Some people are born to weld, others, not so much.
I agree with what was said here... Structural welds are indeed critical. Welding patch panels on the floor not so critical and IMO a great place to start learning!Weld it. If you weld at a professional level do it yourself. If not, practice until you do and then weld it yourself--or hire a fully trained and licensed welder to do it for you.
With all due respect to my fellow do-it-yourselfers, if your welds aren't smooth as surgical sutures but look like chicken dab and require lots of grinding to make them smooth you are not a welder yet and your welds will not stand up to destructive testing. Dabbing grinding and re dabbing etc will not improve the quality of the weld. Be safe, get more training and do more practicing. To produce a safe structural weld it is necessary to know the metallurgy of both the original part, the patch part and the wire and adjust the welding accordingly. It ain't rocket science I know but----
Jack![]()
I would just go out and buy a mig welder and learn. It is not hard to do and after a really short time you will get the hang of it. It is NOT difficult.
After a day or two, with some guidance (you tube) you will realize how easy it really can be.
My welds are ugly as **** still but I get the job done. As long as you clean the metal and get good penetration who cares if you have nice smooth weld beads!
I just did my entire floor repair using a wire feed welder, ugly, ugly welds but a grinder made them look much better!
Oh, my, yes... rivets rivets rivets, with countersunk heads sanded perfectly smooth. Miles of them.air plane skin are put on with silicon and rivets .ships and big buildings were put together with rivets
