nat_ster
Who said he or she's an "armature"?
Most are or they would not be asking questions.
I made my point. I have nothing more to say to you on this topic.
Nat
My 20" raise was essential for making the bus feel good inside. Living in a raised roof bus is wholly different than a stock height one and much nicer.
I did custom hat channel, too. Its in my build thread. I would recommend welding--a good weld is at least as strong as the steel around it. Bolts might feel satisfying, but I'd take a weld any day.
24" is a lot, but nat has good reasons for suggesting it. I did 20.
I also added a window above my windshield which really opened up the feeling of the interior.
I'll look through the build thread to see if anyone's posted pics of this but what are y'alls thoughts on only a partial roof raise? In my mind it seems like the biggest aggravation with such a concept is the fabrication of angled and contoured panels to re-enclose the interior.
I made mine out of fiberglass but if I were to do it again I'd have a sheetmetal shop build it for me.
I love your bus conversion, but cringe evertime I see the way you compromised the roof structure right over the front wheels. That is the most weakest part of the wall structure.
When you cut the roof, the sheeting and rub rails on the walls are forced to take the load that the roof once did.
That would not work out vary well in a roll over.
This is one of the times people are putting looks before strength.
Nat
