tugboater-SKO
I know there are all sorts of threads on here that talk about elastomeric roof coatings. I'm looking for any feedback from folks that have attempted to solve a somewhat common problem.
I patched my roof exits a month or so ago. I did what I thought was a nice, tight job. WRONG! We got a couple days of heavy rain for the first time since they were installed. They both leak, one was bad...the other not so much. Fortunately I was watching & had buckets to catch the water before it ruined my nice new floor! I was able to figure the problem by blowing air up into the rivets...several of them were blowing bubbles topside. I drilled them all out & used 1/4" sheet metal screws (up from 3/16" rivets) to fill all the holes this time. I covered each hole & screw threads in sealant first, tightened them up & goobered around the heads with sealant as well. I'll let things cure overnight and simulate a downpour tomorrow to see how the second try holds up. I think I'll be good to go.
Anyway, as long as there are NO leaks... as insurance, my plan is to tape off each patch to about an inch our two either side of the rivets/seams & coat with Flex Seal or some other elastomeric like coating. I'm not going to paint the whole roof with the stuff. I'm looking for something with the consistency about halfway between the sealant that comes out of a caulking gun & just regular paint. I've got marine maintenance enamel for the roof, but want it sealed up good before I take that step.
What product have you all had luck with?
I think I'm going to buy a gallon of the white Flex Seal unless someone calls that out as a poor decision. Again, I'm only planning on using this as insurance, only applying once I know I'm leak free without it.
