JenniferWillow
‘ELSEWHERE’ 1997 International 3400,T444e
Hi folks,
This weekend my wife and I installed a Dickinson Marine Newport Explorer propane heater in our 24 foot bus. We have a wheelchair door at the back on the passenger side and the heater is installed on the wall just in front of the wheelchair door. I’ve got the electric (12 volt) run to the heater but I’m a little worried about the propane line? The heater is directly above the right side rear double wheels. I have a ASME tank between the main rails behind the rear bumper. I had thought to just run the propane line under the bus to directly under the heater and cut a hole for the propane line to run through. However, given that the heater is directly over the tires I’m having second thought?
We have a tall bus and the propane line would run attached by hose clamps to the bottom of the bus floor. It would turn upward to a hole directly over the tires.
Is this a good idea? I’ve followed the theory that I should keep the propane hoses out of the interior as much as possible. I’m thinking of essentially cutting a hole near the bus centerline either just before or just after our bed platform and doing the centerline to wall run inside the interior. That would keep the propane hose away from the wheels but put 4 feet of hose running inside.
I could really use an outside perspective on this question. Any opinions out there?
Sincerely,
Jennifer
Sincerely,
Jennifer
