TheHubbardBus
Back to work on Rusty 87!
Is your bus jealous of the bus you been driving? Does it still know you?
An unfortunate aspect of these pine step treads that I used for building my cabinets is that they have a bit of a grainy textured surface that so far keeps coming through the paint. I probably should have sanded them before painting. Hopefully the final coat will be thick enough to cover it, or I may have to keep applying coats until it goes away.
Trying to paint away an underlying texture is generally an effort in futility. If getting rid of that is important to you, you might consider sanding what you've got now until it's perfectly smooth & flat (220 grit), then another coat or 2.
Try Sherwin Williams, I think they can match colors.Hmm, that sucks. I'm running low on paint and the variety I've been using (white Valspar satin porch paint) isn't available anywhere any more. I'm going to need to find some new paint to use - it's weird how trying to match white is so difficult.
Inquiring minds want to know, one of the rears, inner or outer? 8 year old tires, recaps or virgin? What happened, I wouldn't have expected a puncture to result in a sudden, catastrophic air loss. I'd really be interested to hear the particulars as I'm going to have to buy at least rears this summer. I found a shop in Allentown that seems to have everything I might consider and if you can provide information to lean me one way or the other I'd appreciate it.
Thanks.
It was the rear inner tire on the passenger side that blew. I had just exited the highway after about 10 minutes of 60 mph and had slowed down to about 40 mph when I heard a big bang underneath the bus. None of the cars around me reacted in any way or tried to get my attention, so I assumed I didn't have any giant chunks of rubber flopping around.
I don't know if they're recaps or virgins - is there a way to tell? I have heard that they tend to blow when it's hot and they're not properly inflated (?). I haven't really checked the pressure on any tires in a long time so perhaps this was pure negligence on my part. I like to go home via the highway so I can get the engine fully heated up since I haven't been driving the bus every day like I was last year, but I might go back to more leisurely routes.
I'm going to try to find a place to put new tires on, and maybe they'll tell me my old ones are still fine (all three shops I've been to over the last three years told me the tires are good and not to worry about them). I'll let you know anything I learn regarding prices etc.
On the paint, I would suggest getting some more modern paint that is as close a match to your color as you can get, then use your preferred third of a gallon as a final topcoat. Not a perfect solution, but it would let your final coat be the correct color. It would be better if the new paint is a hair lighter than the final coat.
Table of Contents:
- The initial catastrophe
- Back corner repair
- New rear lights
- Floor rebuild
- Cab floor repair
- Bulkhead wall
- Dowel subfloor
- End cap framing
- Ceiling insulation
- Vent fan roof projection
- Wall framing and insulation
- Insulated window inserts
- Wheel well boxouts
- Wall paneling
- DIY terlet
- Window pillars
- Ceiling panels
- Countertop framing
- Exit door insulation
- Sink install
- Bed install
- Stove install
- Hinged countertop/table
- Chaise deconstruction/reconstruction
- Hinged desk
- Nunchucks
- Freezer->fridge install
- Butcher block cart rebuild
- Overhead storage bins
- Cabinet doors
- Under-bed drawers
- Skyhatch
- Rear end paint
- Fender repair
Albums:
