Native-SKO
- Joined
- Sep 12, 2015
- Posts
- 3,860
Best laid plans of mice and men!
Hmm, I just realized that when I fabricated the chassis clips for my rebuilt floor section, I not only spot-welded the heads of my Grade 5 3/8" bolts to the brackets, I also quenched the pieces in water immediately after welding them (on one of them I even spot-welded the shank as well as the head). They all pretensioned fully without snapping when I installed the clips. No more welding bolts for me, but maybe I won't die because of this. :hornet:
put some heavy weight oil in a spray bottle and use that to quench the bolt welds it will help retain the temper
Bolt hole welding experiment.
Meh.
Little strip of metal is just too thin, just sizzles away. I'm going to try this again with little bits of 14 ga. These 3/8" holes are the perfect size to be really annoying to try to weld over.
I want to say that I beat the **** out of this strip to test the welds, but I actually just thought it was completely over another piece of floor and I was trying to flatten it to that. I forgot it was over a gap. Fortunately the welds did hold. This floor looks awful but it's solid at least.
It is times like this where ox/acetylene welding shines.
Yeah, exactly!
Wow, I just looked at the timestamp. This picture was taken over 3 years ago!
Sorry about the limited detail of the welds ... this was the best I could find in my camera ... which is an old cell phone with limited resolution.
With oxy acetylene you can braze, so you don't even need to melt the base metal. Super versatile tool. You can work with a wider variety of base metals. They can be plasma cutters, or tube benders, or bolt busters. And, IMO, the learning curve is easier than a MIG.
Fitting a small piece of 3/4" plywood to go under the engine cover and allow me to reattach it.
Problem: not one of the damned screws will go back into the hole it came out of. These were extremely rusty and I treated them with ospho a couple of times. I'll see if wirebrushing the **** out of them fixes it ... if not, anybody know where I can find a set of screws for these? Midwest Bus Parts has all kinds of bus stuff but not these screws, apparently. Conveniently, this engine cover uses four different kinds of screws.
I'm really really really scared of stripping out one of these holes. This is not a location that I want to muck about with retapping holes.
