Native-SKO
- Joined
- Sep 12, 2015
- Posts
- 3,860
Looking at that last picture, one would never imagine what a rotten mess it used to be. Great work.
looks great, very nice on the insulation. Must be nice to work inside now, maybe your body heat can heat the place up.
Johan
Attention to detail or OCD?
They are not mutually exclusive!
I like your use of hardwood as anchor points. I am anxious to see how well they work out with weight and travel.
These prototype pieces for this angled furring strip ended up with an edge bigger than 3/4", so this little ridge was sticking up about 1/8".
Some careful nibbling with a flap disc smoothed it off. All the other pieces that I mass-produced were accidentally the right size on this face, so I don't have to do this all down the bus.
Laid out the stern sheet (?). The left side of this was a 45 degree bevel cut which was pretty tough to manage on my table saw with a piece this long. It was pretty jagged but it smoothed out nicely with my orbital sander.
At this point I realized I would be facing a monstrously frustrating task of smoothing this off and getting it to fit correctly so I cut it in half.
This outside corner came out pretty well.
Other side. Pre-drilling and countersinking all the screw holes is annoying, but it sure makes putting the piece up pretty easy.
More ceiling insulation.
Step 1 in my misguided attempt to put the ceiling up with no help. I figured I would just sort of slide the piece over these blocks and then wedge in a 2x4 on the other end.
Screws are every 6" and these center sheets are 16" on center.
This was I think my fourth attempt. The first two times the sheet fell on me and the third time I actually got it in place with the 2x4 wedged under it, but then when I tried to tap-move it into the correct position the 2x4 came loose and fell on me and then the sheet fell on me. This time I added another 2x4 before shifting the sheet.
I think I'm going to get my brother to help me with the other two of these full center sheets.
One paralyzed right hand later.
The join is not as nice as I'd hoped for. My wall bows in slightly here where it meets the factory edge of the ceiling sheet. Oh well, it was perfect in my head at least. I'll think about ways to make this look better in the front.
I'm going to be painting all of this, but this might have looked kind of nice with some stain and polyurethane. I love the look of wood, but strangely I find being in an all-wood room to be kind of oppressive. I need my environment to be mostly white and bright, especially in winter.
My starter interlock circuit is still active and I'm going to wire the latches into it so I have to remember not to leave them hanging up when I drive.
Could you wire in a latch to your power cord that would lock out starting when it is attached? That would solve the "driving off without disconnecting shore power' problem. Just a thought.
I'm thinking a small, panel mount, 120v light in the dash. Just wired to shore power
Hot Damn Musigenesis, I think you’re gettin’ there !!!
