Rv converter help :(
Frogpondfoug
Mar 3, 2019
143
Manitoba Canada
I recently picked up a converter from a RV. System monitors inc mrm400d. I understand most of t he wiring just few on the tag that dont make sence. Can somone explain the wiring on this tag :) does white mean battery ground?
'COMMON' and 'NEG' are alternative references to ground in both AC and DC applications, so seeing as everything else is marked 'LINE', 'BAT', or '+' (which means 12V), I would say yes. White is an odd color choice for a 12V ground wire (usually lighter colors are 12V, darker are ground), but assuming this is a DC-to-AC inverter we are talking about, it might make sense on the output side, though white is usually neutral in AC wiring.
I would, however, suggest contacting the manufacturer to see if they can provide a proper wiring schematic. I fried a fairly new CB radio in an Intertrashable PornStar because it used a white wire for ground, and a green wire for 12V DC, with no labeling :facepalm:
Hope that helps!
