seats with belts- well mine anyways
All seats in the short bus have built in seat belts. All are cloth.
I have seats from 2017 and 2018 Ford transit vans, Not the transit connect, the big full size 15 passenger vans. These are doubles. These seats can also be removed from bolt in seat latches. You do not need tools to remove the seats, just pull the latch release. The mounts are bolted to the floor. They are about 2" thick, so if you have insulated the floor and plywood, it is possible that the seat mounts are at or below floor level. Means your floor is flat with out the seats in it. The floor mounts have tie down anchor points, so when the seats are out, you can "tie" on to anchor points. Anchor points are forged from the looks of them. Mountings are way way over built.
I would expect safety factor of five or six... That means the engineer came up with numbers needed to do the job and then went five or six times stronger than that.
The doubles, have one seat with baby seat latch points, one seat has an arm rest - the side that was intended to be the "outside" seat. Head rests move up and down. Triples have baby seat latch points on both outer seats.
Transit doubles are about 37" wide and use about 28" of space front to back. weighs - a guess about 45 kilos -100 lbs
Transit triples are about 56" wide and use about 28" of space front to back. Weighs - a guess about 90 kilos - 200 lbs
I will have seating for ten, three doubles, and four singles. The single seats, from the trucking industry, massage, fully recline, swivel, adjust about 14 different things, and are about 20 inches wide at the seat bottom and 26" wide at the arm rests. Cost about $1000 to $1500 each I have to have air and electrical power to make them fully functional.
All people are expected to be belted in while driving or parked on a shoulder.
Three of the adult passenger seats have the ability to swivel, but are expected to be locked in forward or rear ward facing most of the time. Exceptions - tending to little ones, like getting drink, food, stuff like that.
