Lherrlinger
Just moved I can use my NC address or my moms Sc address which would be easier to register will I have to change my title? Anything helps thanks
Unless you have a cdl, definitely. You can’t legally drive a school bus unless it’s changed over. Plus insurability and taxation advantages.
Is it better to have changed into an rv title?
Why then, do you need a cdl to drive a church bus? Is that technically commercial? I’ve always assumed that a cdl was needed on that basis but could be wrong, it’s happened before. A lot.
so let me get this straight. If the bus is classified as a rv you don't have to have a cdl?
