lornaschinske
I used Snow Roof's Elastometric on the Class C (roof coating, "tape"& primer) works wonders and no more leaks on the roof. Lowered the summer temps quite a bit. Down side is I have a "dip" towards the rear and Snow Roof doesn't like standing water (ponding is what they call it). So if you have a flat roof, you need to watch for that. I did the roof in 2006 or 2007 and had to have the primer ordered in.
For the skoolie (rounded roof, no standing water) we used Henry's Solar-flex from Home Depot. I used the "tape" I had left over from doing the Class C and embedded it into the Henry's to seal leaks. Then put two coats of roof coating on the roof. Really needed three coats but it was too hot. Henry's makes a clear elastometric caulk that you can use to seal leaks with (I have bought several tubes at Home Depot. Apply on WET or dry surfaces. The large 4.75 gallon bucket will cover a 40 ft bus with 3 coats. I used a paint roller.
