Wheel wells + floorplan = lifestyle
Thanks, this helps a lot actually, as we hear from more people and watch more videos we are getting an idea of how much room we need and how people go around in town. Its opening up our eyes a bit more. We love being outside and are used to living in a small space. We may just go with the biggest bus we can get �� Thanks for the info.
Since you are open to suggestions and considering all the options....
Rear engine buses have longer wheel bases. I first thought about turning radius, campsite limitations, etc. But for us, that's not important. We wanted volume and a side hallway.
Many new buyers are surprised that the rear wheel wells have so much impact on their pre-purchase floorplan. Dognose and FE flat nose buses have the same problem. Six and a half windows to the rear wheel humps, long overhang behind.
Our RE has nearly 10 windows between the humps.
Dognose: from entry door to humps, 6.5 windows
Flatnose FE: from front hump to back humps 6.5 windows
about 27" each window, about 15 feet.
RE buses: 7 to 10 windows from hump to hump up to 22 feet between. That's an additional 7 ft of walk around.
(Note: the rear wheel wells begin near the back of the 12th window.)
An all inclusive, full size bathroom is a great place to have quality time while preserving water rations. Shower in the arch with 6'6" headroom. No swinging doors, one slider. At home, we usually leave the door open, when we wee. The bathroom door is not visible from elsewhere, on the bus. Wide open chassis, below.
The floor plan above would work in a flat floor handi bus (fiberglass or steel) or a long wheelbase RE, only.
(blocking out the floorplan to assess a side hall)
IC Corp's 303" wheelbase (25'3") RE300 is 42'2" long, overall and they're claim, "has the widest entry in the industry".
(5ft x 5ft and 36" x 80" door, tall & wide)
If you are living full time with kids, you may need the space at the entry. Look around your current home's front entry. Do you put various items near the entryway, then a motor hump and narrow stairs won't be great. Tiny home life will force lifestyle changes, more space up front is a treasure for house keeping. Just as a full private bath, that all can use, is a special space.
All this and thicker body steel too. Built using 16g body steel since the mid 2000s. If you want to go long, this is it. Those who intend to travel narrow roads, & stay in small campsites, disregard.
