cofrari
I had the idea of adding a second fresh water tank to the roof of the bus which would only be tied into the Hot Water on the shower. My thought is that in the warmer months, the sun would warm the water to a high enough level to where it would be satisfactory for the shower without the need to use the hot water heater. For the cooler months, I would have a way to switch the hot water back to the main fresh water tank in which case it would run through the propane powered hot water heater.
My only thought is that I should use a clear tank for the roof to prevent any kind of mold to grow (seems like a clear tank would reduce any chance of that happening). I would need a second pump of course. I can get a 20-gallon tank that is only 4 inches high, so I don't think it would add a whole lot of wind resistance. And I'm probably looking at about 250 pounds of weight. And this would only be for the shower - not for any type of internal consumption.
Is there anything I missing with this idea?
