Sleddgracer
2.5 hours after putting these 2 test pieces up. I'm good with either LocTite product for this application. Now I get the sawzall to cut those samples down.
Here's 100lbs hanging from them.
that's impressive
that's impressive![]()
Quite handy, Remember the grommets!I just went out and whacked with a hammer and they came off easily, but they hold the weight and I'm good with it.
Need to start wiring and was pleasantly surprised to see a hole through the fore/aft ribs in every single section to run wires through, I had planned on drilling my own.![]()
I made a few "T" braces in the profile of a ceiling rib the exact length floor to rib. They should work perfect on the 1/4" panels going up.
I'm planning on using some underlayment in 1/4" down the center of the bus and then 1/4" T&G boards from there down. Would I be making a mistake gluing these boards and panels. I don't want a bunch of fasteners showing.
:Thanx:
Keep some tape and or shims handy to get them braces just right for height, you may find a little variance.
Mark,
Are you using all rigid foam for your insulation. Just curious. I'm finding it hard to get a spray foam contractor to commit.
Nice work on the experiment! I just LOVE a little scientific process.
