Shapeable aluminum material
adic27
May 15, 2017
573
Houston TX
Anyone know what I can use for/to create a 47x47 inch cheap drain pan for a pop up camp shower? Something I can add a drain to, even if it's a simple whole with pvc pipe into a 5 gallon bucket. Imagine one of those big aluminum foil pans you bake a lot of food in. Something like that but maybe like an inch to an inch and a half and of course 47x47 inches
Thanks
Edit: something like this would be perfect but 47x47 inches..
https://www.lowes.com/pd/CAMCO-Washing-Machine-Drain-Pan-White/50195165?cm_mmc=shp:sleep:c:sleep:prd:sleep:app:sleep:google:sleep:lia:sleep:174:sleep:laundry:sleep:50195165:sleep:0&placeholder=null&ds_rl=1286890&gclid=Cj0KCQiAvbiBBhD-ARIsAGM48bzuTy7SLJGEIVB1dxQkxmceoNsgnqY5iKRl-BIIZ-x4eEuwH35eRtwaAh7YEALw_wcB&gclsrc=aw.ds
Probably have to custom make that. 47x47 is not exactly common, and an aluminum foil pan would not do the job. Maybe you were simply using that as an example?
Anyhoo, good luck. A custom pan made in that size from 1/8"or 3/16" aluminum shouldn't cost too much to have made?
I posted a link of a better example and probably better option but didn't do it right. It's fixed now.
A house water heater usually has something like that under it as well. Might be round shaped?
Don't know what sizes are available though...
