Kentucky Dreaming
Tanker, a few questions and then you need to do some visual work and take more photos.
The inverter should have nothing to do with running a 12 volt direct current air conditioner, In your pics, there is nothing plugged into the cord on the output side. It's hard to tell from the angle but I can't see any wires attached to the input lugs on the end of the inverter against the passenger side wall of your bus. And if you have no house battery, where would the 12 volts be coming from? only answer is your starting batteries. Can you verify this by eyeball and photo?
That being said, you don't need an inverter to run your unit. You say you think the doofus hooked the unit to the alternator. What makes you think that? You really need to trace the wires from the unit to the other end and document with photos.
We want to help, but you need to do some simple investigation and provide a few answers. How do you eat an elephant? One bite at a time.
