fordthomas
So, what’s the best way to wire your skoolie so it can run off of either solar or hooked up to say a house?
Our inverter / charger has a transfer switch built in, and accepts separate inputs for both shore & generator power. Hooked up to one or both, you can charge the batteries and/or pass-through AC to the house circuits. An all-in-one unit made it much simpler, and with the inverter controlling it all you have interoperability / logic that wouldn't be possible with separate components.
Of course, if the plan is to have multiple air conditioner units cranking away all day...then that would merit shore power to the AC circuits...and that's not a system I'd have. I take that back...I do have that system in our MCI bus, but that conversion was set up that way before we bought it. It's a "typical" RV-style system and that's not what I like to do.
We actually did things a little different, Ross. We simply don't have the real-estate for enough panels to power a house A/C in situations where I'd consider it necessary, but I did want the ability to run one when A) anywhere we had access to 30A service, andvia generator as an 'emergency' option boondocking. I also didn't want the inverter to be involved, since doing so would require a significantly larger unit that would only be required in the very rare times we were running A/C.
My solution was to use a 30A rotary switch capable of accepting 2 inputs. It's meant to switch between shore & generator power and direct what you choose to 2 separate circuits. But I wired it so it swaps the outputs, one of which goes directly to the A/C unit, the other to the inverter. When I turn it to 'shore', the A/C unit is directly powered by the shore power inlet, and the generator is routed to the inverter for charging and/or AC pass-through. When I turn it to 'generator', it's the opposite... the generator directly powers the A/C unit, and the shore input is routed to the inverter.
Another benefit of this arrangement is I don't have to have a battery bank in place to run the A/C. During the summers I plan on removing the battery bank when the bus isn't in use to keep it at a friendlier temp. If we powered the A/C through the inverter, that wouldn't work, since our inverter requires a DC power source to function, even in AC-passthrough mode. But since the A/C is essentially isolated on its own circuit, that's now a non-issue. Good for working on the bus in the hot, hot summer.
