Should I remove ALL of my floor?
Oct 13, 2021
16
Southern California
Hello! I have completely gutted my bus, with the exception of the drivers seat/hardware/dash etc and the AC unit at the front. It doesn’t appear to have much rust under these areas.
Question: should I just have my new flooring stop right before the drivers seat/AC, or should I gut EVERYTHING and have my new floor go all the way to the dash. Thanks in advance, you guys are the best.
- Eric
School buses aren't built with ride quality as a priority. In fact, school buses are very noisy things to ride in on the highway. that bus load of kids screaming at each other....they're not just trying to talk over each other, they're also talking over the bus noises. So, even if you are not concerned with floor insulation as a thermal barrier, consider it as a noise barrier. You'll be glad you did.
On my bus, I left the original floor in place at the right (front side) of the steps over to the driver's seat base. That little bit of floor can't be walked on so when I finish that area, I'll apply a sound deadener over the rubber matting and then install my carpet.
The floor at the top of the steps, I have sound deadener directly on the metal, 1/2" plywood which will have carpet on it eventually. The driver seat actually sits on a raised platform, when I replace the seat, the platform will get sound deadener and a new heavy rubber mat to replace what was there originally.
With the floor insulation I have installed in the "camper" area so far has made a very noticeable difference in the noise coming from the engine.
That area under the dash and the driver's seat is one of the most rust-prone areas in the bus so you probably want to take up the floor all the way to the front - especially if you've found severe rust damage elsewhere on the floor.
