electricwitness
- Joined
- Aug 6, 2012
- Posts
- 16
Hi new to this bus conversion game, not new to mechanical and automotive stuff.
I have a 1991 Ford e350 Terra Transit/Turtle Top shuttle bus. I am going to have to replace the entire floor including the braces, not cool. I did a very poor inspection on this purchase so now I am dealing with it.
My question at this time is in regards to the construction of the walls. I have removed one wall covering and had a lot of plywood fragments fall out. All of the glue has disintegrated from between the plyes. It looks like there was a thin layer of plywood glued to the fiberglass or aluminum sheet of the wall. Does any one know if that layer is structural or if I can replace it with rigid insulation? I have searched but not been able to locate the info i need.
Lots of good info here!
Thank you
Thank you
