Clarity maybe
Codes: 343 Excessive Exhaust Back Pressure
327 Power Reduced to Match Cooling System Performance "M"
Service Performed:
-EBP sensor replacement
-EBP Tube cleaned out (with sensor removed, there's a healthy flow)
-MAP sensor replacement
-Turbo replacement with no effect. (Reinstalled the old turbo to prevent damaging the new one)
-visual inspection of harnesses for corrosion/bent pins
-ServiceMaxx J1708 - snapshots of warm-up and a short move (hopefully I did this right)
-Controlled VGT via ServiceMaxx and verified operation (Duty Cycle, Vanes open and hold as demanded)
I am conducting circuit tests today on all sensors, VGT actuator and EGR valve. I did some resistance checks before, but now I think I may have a better comprehension of the procedures and I want to record my results. I wonder if somehow a short is causing the pulsewidth signal to the VGT actuator to such a high duty cycle, but I wonder why I am not getting a code for VGT over duty cycle. If those screenshots actually post, the green dotted line that seems to be all over the graph is the Turbo Duty Cycle%. It stays frozen at 353% with intermittent drops to 30-80% for a fraction of a second.
I will try to collect more information on the electrical testing, and if anyone wants to see some specific info under certain conditions, please lmk. Thanks for your time and attention.
Service Performed:
7B427163_Performance_2022_11_03_14_30_47_442en_US.slk.jpg139.2 KB · Views: 19
7B427163_Performance_2022_11_03_14_30_47_442en_US.slk_1.jpg139.4 KB · Views: 18
7B427163_Performance_2022_11_03_14_30_47_442en_US.slk_2.jpg143.5 KB · Views: 24
7B427163_Performance_2022_11_03_14_30_47_442en_US.slk_3.jpg150 KB · Views: 18
7B427163_Performance_2022_11_03_14_30_47_442en_US.slk_4.jpg150.6 KB · Views: 15
7B427163_Performance_2022_11_03_14_30_47_442en_US.slk_5.jpg150.8 KB · Views: 17
7B427163_Performance_2022_11_03_14_30_47_442en_US.slk_6.jpg150.8 KB · Views: 17
7B427163_Performance_2022_11_03_14_30_47_442en_US.slk_7.jpg149.8 KB · Views: 14
